Guest Posted November 13 Report Share Posted November 13 Can I bake RustSeal to speed up the cure time? I would like to put it in the booth and bake it. Quote Link to comment https://success.kbs-coatings.com/topic/7309-bake-rustseal-to-speed-cure/ Share on other sites More sharing options...
KBS Coatings Posted November 13 Report Share Posted November 13 RustSeal is a moisture cured urethane (catalyzed by moisture in the air), so dry heat from baking can actually slow the cure of RustSeal. You can speed the cure of RustSeal with air flow and humidity (humidifier, wet towels on the ground, etc.). Always allow RustSeal to cure normally until it it is dry-to-touch and does not leave a fingerprint, and then add the air flow and humidity. RustSeal TDS and Detailed Application Directions: https://www.kbs-coatings.com/rustseal-directions RustSeal Link -> https://www.kbs-coatings.com/rustseal Please reach out if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/7309-bake-rustseal-to-speed-cure/#findComment-10084 Share on other sites More sharing options...
