Showing results for tags 'rust protection'.
    • Announcements
Found 3 results
  1. I just welded a rear quarter panel on and was thinking of using this as a seam sealer to cover the weld seams and then sand it smooth. Would it be best to paint RustSeal first, then push this epoxy into the seam sand it smooth then top coat with another coat of RustSeal for protection?
  2. “Frame up Restoration of a 1980 Chevy K10. Coated the springs, differentials and other assorted parts that will be out of sight. Coated with RustSeal after sandblasting. As advertised these products appear to be the easiest and most durable to use.” - Michael P. Check out RustSeal
  3. For a new truck that has no rust protection what do you recommend? Also doing a frame off restoration what do you recommend?
