October 6, 201610 yr comment_3900 I'm used your Diamond Finish Clear on my head lights. How long should I wait for the Diamond Finish Clear to cure before it's exposed to rain and the sun? Link to comment https://success.kbs-coatings.com/topic/2127-diamondfinish-clear-on-headlights/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 6, 201610 yr comment_3901 Once headlight is coated, allow DiamondFinish Clear to dry (typically 1-2 hrs to touch). Allow overnight curing before putting lenses back into service. One coat is normally sufficient for lasting protection. A 2nd coat may be applied any time after 48 hrs. Please check out the Headlight Restoration Kit Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2127-diamondfinish-clear-on-headlights/#findComment-3901 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 3, 20169 yr comment_3967 When you properly prepare and coat polycarbonate headlights with Diamond Clear, can you please explain the drying time in relationship to... " 1-2 hours to touch and maybe 4 days to thoroughly dry ". Here is my question... You obviously need to energize the light bulbs at some time, when would it be safe since they will generate incredible heat and the lenses with get very hot? Will the heat bubble or blister your clear if not fully cured, should we wait 12 hours, 24 hours, 48 hours, or more? I believe this is an important issue for everyone, can you maybe add the answer to your original instructions on headlights page? Thanks for your technical support, I think your products are awesome. Link to comment https://success.kbs-coatings.com/topic/2127-diamondfinish-clear-on-headlights/#findComment-3967 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 5, 20169 yr comment_3969 It is always a good idea to wait at least 12 hours before turning on the headlights and subjecting the DiamondFinish Clear to the heat. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2127-diamondfinish-clear-on-headlights/#findComment-3969 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 16, 20169 yr comment_3984 That is a great point Gary! I have a "test light" I use and may try and put a DC inverter on it after my next test spray. I am getting used to the settings on the HVLP gun for the best application of DC on headlights. Link to comment https://success.kbs-coatings.com/topic/2127-diamondfinish-clear-on-headlights/#findComment-3984 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
