February 20, 200818 yr comment_1592 Do you make a coating to seal a rusting oil pan? The pan would be degreased, blasted and cleaned first. The coating could go on either side maybe? Link to comment https://success.kbs-coatings.com/topic/961-oil-pan/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 20, 200818 yr Author comment_1593 Most people use the Gold Standard Tank Sealer or the RustSeal to seal their oil pans. Here would be your process: 1) It needs to be cleaned really well with a water-based cleaner like our KBS Klean. 2) Blast it. 3) Blow off the loose dust. 4) Apply 2-3 coats of Tank Sealer or RustSeal. Link to comment https://success.kbs-coatings.com/topic/961-oil-pan/#findComment-1593 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
