January 11, 200818 yr comment_1502 I have surface rust around the rear window sealing edge. What do you suggest to stop this rust and prep before installing the window? Link to comment https://success.kbs-coatings.com/topic/871-window-sealing-edge/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 15, 201610 yr Author comment_3540 This is a common problem and our Rust Prevention System is the ideal solution. The best way is to prep the surface rust with KBS Klean and RustBlast and then coat with 2 coats of RustSeal and 1 coat of BlackTop. Please review the RustSeal Directions and the BlackTop Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/871-window-sealing-edge/#findComment-3540 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
