June 23, 20179 yr comment_4099 Can I paint your Diamond Finish Clear over an oil based paint that has fully cured? If so, how should I prep the surface? Link to comment https://success.kbs-coatings.com/topic/2209-diamond-finish-clear-over-oil-based-paint/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 23, 20179 yr comment_4100 Yes, you absolutely can. Clear Coating Over Cured Coatings:Clean surface with KBS Klean diluted 10 parts warm water to 1 part KBS Klean. Scuff with 600-1200 grit sandpaper and repeat cleaning process. Rinse & allow to thoroughly dry. Please check out the DiamondFinish Clear Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2209-diamond-finish-clear-over-oil-based-paint/#findComment-4100 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
