June 20, 20179 yr comment_4097 I have an interior wooden table I want to clear coat. What would you recommend I should use, aerosol or brush on? Link to comment https://success.kbs-coatings.com/topic/2208-diamond-finish-clear-on-wood/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 21, 20179 yr comment_4098 For a table top, the non-aerosol version of DiamondFinish Clear is the best choice for looks and long term durability. When brushing DiamondFinish Clear, apply thin, covering coats and do not overwork the brush as this can cause the DiamondFinish Clear to cure too quickly possibly leaving visible brush marks. It is best to brush an area with DiamondFinish Clear and move on immediately versus brushing an area over and over again. If you brush over an area over and over again forcing the solvents out, you run the risk of the brush marks not flowing out as well they are designed to flow out. Please review the DiamondFinish Clear Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2208-diamond-finish-clear-on-wood/#findComment-4098 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
