May 22, 20179 yr comment_4079 How long do you leave Rust Blast in an aluminum gas tank to etch the surface? Link to comment https://success.kbs-coatings.com/topic/2202-using-rust-blast-on-an-aluminum-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 22, 20179 yr comment_4080 RustBlast is an acid etch (think chemical sandpaper) and aluminum tends to be smooth. So, at a minimum, each side of the inside of the tank should be etched at least 30 minutes using RustBlast. The surface needs to be wet for the entire time because RustBlast stops working when the surface dries. Please review the entire Tank Sealer Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2202-using-rust-blast-on-an-aluminum-tank/#findComment-4080 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
