May 17, 20179 yr comment_4077 I'm using your galvanized steel Rust Seal. It's really thick and I know in the directions it says you can thin up to 10%. What will happen if I thin it more than 10% because I think it will need it? Link to comment https://success.kbs-coatings.com/topic/2201-thinning-rust-seal-more-than-10/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 17, 20179 yr comment_4078 If needed, you can thin RustSeal more than 10% with KBS #1 Thinner. The RustSeal will just take longer to cure and you might need more than 2 coats to get at least 5 mils of Dry Film Thickness. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2201-thinning-rust-seal-more-than-10/#findComment-4078 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
