April 5, 20179 yr comment_4057 I have a little bit of surface rust on the inside of my tank. I don't want to use a sealer to coat the inside I would just like to use the KBS Klean and Rust Blast to dissolve the rust. Is this something that should work for me? Link to comment https://success.kbs-coatings.com/topic/2193-only-using-kbs-klean-and-rust-blast/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 11, 20179 yr comment_4062 Generally, yes, this will clean and etch your tank. But unless you keep the tank full of fuel at all time, condensation will cause rust down the road, so sealing up the tank with Tank Sealer is always the best option for long term success. Please check out the Tank Sealer Directions and let us know if you have any additional questions Link to comment https://success.kbs-coatings.com/topic/2193-only-using-kbs-klean-and-rust-blast/#findComment-4062 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
