March 24, 20179 yr comment_4044 I'm using some seam sealer and was wondering how to apply the Rust Seal with it. Should I put Rust Seal down first and then seam sealer or seam sealer and then Rust Seal? Link to comment https://success.kbs-coatings.com/topic/2186-rust-seal-seam-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 24, 20179 yr comment_4045 It is always best to prep with KBS Klean and RustBlast first, apply 2 thin, covering coats of RustSeal and then apply the seam sealer once the final coat of RustSeal has cured for 3-6 hours. It is best to get the metal sealed up first with RustSeal before applying the seam sealer. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2186-rust-seal-seam-sealer/#findComment-4045 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
