Guest Posted December 29, 2016 Report Share Posted December 29, 2016 I want to paint my frame with Rust Seal but I have some holes that are about 3"x 3". Can I prep the surface and then put the KBS Patch over these holes in the frame? Is the KBS Patch designed to do this? Quote Link to comment https://success.kbs-coatings.com/topic/2159-kbs-patch-on-rusted-metal/ Share on other sites More sharing options...
KBS Coatings Posted January 20, 2017 Report Share Posted January 20, 2017 Yes. Prep the surface with KBS Klean and RustBlast. Then apply 2 thin, covering coats of RustSeal. Then apply the KBS Patch to the RustSeal 3-6 hours after the second coat of RustSeal to ensure maximum adhesion. Cure the KBS Patch. Then you can paint the KBS Patch with RustSeal. Please check out the KBS Patch Directions and the RustSeal Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2159-kbs-patch-on-rusted-metal/#findComment-3994 Share on other sites More sharing options...
