November 3, 201610 yr comment_3931 I'm doing your 3 step process and I just finished doing the Rust Blast. I just realized I forgot to dilute the KBS Klean with water when I used it. Is this going to mess everything up? Should I start over? Any suggestions would be great! Link to comment https://success.kbs-coatings.com/topic/2138-kbs-klean-forgot-to-dilute-with-with-water/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 3, 201610 yr comment_3932 KBS Klean should always be diluted with water at least 1 to 1 for maximum effectiveness. You can remedy this situation by taking some clean water and a green pad and gently rinsing the surface with the clean water and green pad. Please check out the KBS Klean Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2138-kbs-klean-forgot-to-dilute-with-with-water/#findComment-3932 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
