October 12, 201610 yr comment_3906 I'm going to use your Rust Seal and I want to top coat it with u-pol bed liner. Can I do this? Do I have to scuff the Rust Seal or is there a time frame that I can apply the bed liner without scuffing? Link to comment https://success.kbs-coatings.com/topic/2131-bed-liner-over-rust-seal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 14, 201610 yr comment_3910 There are three effective ways to topcoat RustSeal effectively with a bed liner so that the coatings bond & fuse together. 1) Apply your bed liner once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply your bed liner. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your bed liner. You can feel free to choose the method that will work for you. Link to comment https://success.kbs-coatings.com/topic/2131-bed-liner-over-rust-seal/#findComment-3910 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
