August 19, 201610 yr comment_3854 What is the highest humidity level I can paint Rust Seal in and it still lay out nicely? Link to comment https://success.kbs-coatings.com/topic/2099-rust-seal-and-humidity/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 19, 201610 yr comment_3855 RustSeal is cured by a combination of temperature and humidity. You can also speed up the cure (negatively) by overworking the brush when brushing RustSeal. If it is 80 degrees, it would best to keep it below 80% humidity for optimal brush flow out. You can always help brush marks to flow out by applying thin, covering coats of RustSeal, not overworking the brush, and thinning the RustSeal with KBS #1 Thinner if needed. Please check out the complete RustSeal Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2099-rust-seal-and-humidity/#findComment-3855 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
