August 10, 201610 yr comment_3842 Can I paint Diamond Finish Clear over powder coating? If so, how would I prep the surface? Link to comment https://success.kbs-coatings.com/topic/2093-diamond-finish-over-powder-coating/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 10, 201610 yr comment_3843 Yes, absolutely. This is a very common application because DiamondFinish Clear is UV stable and adds a whole lot of durability to the powdercoated surface. If the surface is glossy, scuff with 300 grit and then wipe down the surface with KBS Klean. Please check out the DiamondFinish Clear Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2093-diamond-finish-over-powder-coating/#findComment-3843 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
