August 8, 201610 yr comment_3839 I want to paint my brake calipers. What would you recommend for this? Link to comment https://success.kbs-coatings.com/topic/2091-brake-calipers/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 9, 201610 yr comment_3841 That is an excellent question. Coating brake calipers with our paints is a very common application. If you have sandblasted the brake calipers, you can simply apply 2 thin, covering coats of RustSeal (to prevent rust) and then 1 coat of Motor Coater in the color of your choice. If you have not sandblasted the brake calipers, clean with KBS Klean, etch with RustBlast, then you can simply apply 2 thin, covering coats of RustSeal (to prevent rust) and then 1 coat of Motor Coater in the color of your choice. Please check out the RustSeal Directions and the Motor Coater Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2091-brake-calipers/#findComment-3841 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
