Guest Posted May 18, 2016 Report Share Posted May 18, 2016 I purchased the XTC primer quart kit and I forgot to add the zinc dust to the paint before I painted. What do you recommend I should do? I want it to last but with out the zinc dust it may not. Should I remove it and start all over. Quote Link to comment https://success.kbs-coatings.com/topic/2034-xtc-primer/ Share on other sites More sharing options...
KBS Coatings Posted May 18, 2016 Report Share Posted May 18, 2016 The zinc dust component is what provides the rust prevention of the XTC Primer. So, if you apply the XTC Primer without the zinc dust component, you will want to remove that coating and apply XTC Zinc Primer after you have mixed both the zinc dust component and base component together. Please check out the complete XTC ZInc Primer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2034-xtc-primer/#findComment-3708 Share on other sites More sharing options...
