May 17, 201610 yr comment_3705 I'm looking to seal my gas tank but not sure if I need to purchase your strip or not. The inside of the tank is really dirty and it's hard to tell if there is a sealer already in the tank that should be removed. Any recommendations with trying to find out if there is a sealer already in the tank? Link to comment https://success.kbs-coatings.com/topic/2033-sealing-a-gas-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 18, 201610 yr comment_3707 If you think there could be an old sealer in your tank, it is best to use the KBS Strip to get that out first. After you have stripped the old sealer out, prep the tank with KBS Klean, RustBlast and then seal up the tank with Tank Sealer. Please check out the Tank Sealer Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2033-sealing-a-gas-tank/#findComment-3707 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
