April 21, 201610 yr comment_3674 I'm painting your rust seal and I want to top coat it but you don't carry the color that I need. Can I use another type of paint to top coat over the rust seal? Link to comment https://success.kbs-coatings.com/topic/2017-top-coating-rust-seal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 21, 201610 yr comment_3675 Yes. You can top coat RustSeal with other solid color top coat paints. There are three effective ways to topcoat RustSeal effectively so that the coatings bond & fuse together. 1) Apply your top coat once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply your top coat. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your top coat. You can feel free to choose the method that will work for you. Please review the RustSeal Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2017-top-coating-rust-seal/#findComment-3675 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
