March 17, 200818 yr comment_1596 Is KBS Klean suitable for use prior to spraying automotive paint? I'm looking for a solvent to remove oils, wax, grease, and silicone from *painted* surfaces prior to coating, but preferably a water-based solution. Right now I am in the middle of sanding the existing paint before I spray some sealer and want to get rid if any sanding residue and the like, aka above from the surface. It sounds like KBS Klean is suitable for all surfaces. Just looking for some feed back before I prime and seal. Link to comment https://success.kbs-coatings.com/topic/965-sanding-residue-prior-to-paint-automotive/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
February 13, 201511 yr comment_3121 Yes, KBS Klean is an excellent cleaner that removes all kinds of oils, waxes, greases, and silicone residues making KBS Klean ideal to use prior to painting a surface with an automotive paint. Please let us know if that helps and if you have any additional questions. Thank you for choosing KBS Coatings! Link to comment https://success.kbs-coatings.com/topic/965-sanding-residue-prior-to-paint-automotive/#findComment-3121 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 26, 20169 yr comment_3960 So is it o.k. to be used in place of a painter's wax/grease remover? Link to comment https://success.kbs-coatings.com/topic/965-sanding-residue-prior-to-paint-automotive/#findComment-3960 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 15, 20169 yr comment_3980 Yes, you can use KBS Klean as your wax and grease remover. Link to comment https://success.kbs-coatings.com/topic/965-sanding-residue-prior-to-paint-automotive/#findComment-3980 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
