Entire Cab & Bed
I am going to be doing the entire cab and bed of my truck with RustSeal and was wondering if there is any difference in these two colors or do they work the same? Does the silver have added metal in it to help with rust and pitting or any other added benefits? I am going to be using the "satin" BlackTop paint over the RustSeal in areas that will not be covered with carpeting.
Will the "satin" BlackTop paint cover and work over the "silver" RustSeal, or do you suggest using the "satin" colored Rustseal as a bottom base instead? Sorry for the rambling, but thanks for any help you can suggest on this.
Quote
Do they work the same?
Yes. They work the same. The silver will be better for pitted areas, but they are essentially the same except for the color.
Quote
Will the BlackTop paint cover and work over the "silver" RustSeal, or do you suggest using the "satin" Rustseal as a bottom base instead?
It is probably easier to paint BlackTop OEM Satin Black over RustSeal Silver, so that is how we would do it. You can easily tell where you have painted and where you have not.
