Guest Posted October 16 Report Share Posted October 16 I am adding steel D-rings to a new aluminum trailer and wants to avoid a galvanic reaction between the metals. Do you have a solution? Quote Link to comment https://success.kbs-coatings.com/topic/7275-prevent-galvanic-reaction-between-metals/ Share on other sites More sharing options...
KBS Coatings Posted October 16 Report Share Posted October 16 RustSeal will permanently seal the surfaces creating an impervious barrier that will protect against a galvanic reaction. For the d-rings, prep and coat the surfaces that will come in direct contact with the aluminum trailer. As always, RustSeal is applied in thin, covering coats and at least two coats. Let the RustSeal cure fully before installing the d-rings. Check out RustSeal -> https://www.kbs-coatings.com/rustseal RustSeal complete application directions -> https://www.kbs-coatings.com/rustseal-directions Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/7275-prevent-galvanic-reaction-between-metals/#findComment-10043 Share on other sites More sharing options...
