KBS Coatings Posted July 27, 2022 Report Share Posted July 27, 2022 How To Attach The Cavity Wand to KBS Cavity Coater Aerosol In this video from KBS Coatings, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can. The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F. Cavity Coater is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. KBS Cavity Coater provides a self-healing film which provides insane rust protection on hard to reach areas. Link to comment https://success.kbs-coatings.com/topic/3009-how-to-attach-the-cavity-wand-to-kbs-cavity-coater-aerosol/ Share on other sites More sharing options...
