Showing results for tags 'cavity wand'.
    • Announcements
Found 5 results
  1. How To Attach The Cavity Wand to KBS Cavity Coater Aerosol In this video, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can. The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F. Cavity Coater Aerosol is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. Cavity Coater Aerosol provides a self-healing film which provides insane rust protection on hard-to-reach areas.
  2. How To Attach The Cavity Wand to KBS Cavity Coater Aerosol In this video from KBS Coatings, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can. The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F. Cavity Coater is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. KBS Cavity Coater provides a self-healing film which provides insane rust protection on hard to reach areas.
  3. How do you clean the tube and head of the wand after using it or do you need to?
  4. Dan
    Cavity Wand
    Does the 17.5 ounce Cavity Coater can come with a wand to get inside doors etc.?
  5. "I purchased in November but was finally able to put the stuff on today. I bought the Cavity Coater with spray gun and 36" wand. This process went so much smoother than expected. Once I figured out the psi and the nozzle without the wand it was kind of fun. Customer service has been great! I called 3 different times and each time has been very pleasant, informative and helpful. I asked about regulator settings for the spray gun and set it up at 55psi. Worked great. Time will tell if the Cavity Wax stands the test. I am optimistic to say the least. I sprayed both rockers, 4 full sized doors, both front fenders, tailgate, rear bumper and basically the whole inner bed sides (fenders) on my 2014 Ram crew cab 6.4' bed. Thanks guys! I may be looking to do the frame kit package this spring!" Keith C. from Stilwell, KS
