Showing results for tags 'cavity coater'.
More search options
    • Announcements
Found 4 results
  1. How do you clean the tube and head of the wand after using it or do you need to?
  2. Hi i will be treating mt 95 jeep yj frame with cavity coater how long does it take to dry? also once dry can i spray other products on top of the cavity coater such as fluid film for a rust maintenance program .Thanks
  3. Dan
    Cavity Wand
    Does the 17.5 ounce Cavity Coater can come with a wand to get inside doors etc.?
  4. "I purchased in November but was finally able to put the stuff on today. I bought the Cavity Coater with spray gun and 36" wand. This process went so much smoother than expected. Once I figured out the psi and the nozzle without the wand it was kind of fun. Customer service has been great! I called 3 different times and each time has been very pleasant, informative and helpful. I asked about regulator settings for the spray gun and set it up at 55psi. Worked great. Time will tell if the Cavity Wax stands the test. I am optimistic to say the least. I sprayed both rockers, 4 full sized doors, both front fenders, tailgate, rear bumper and basically the whole inner bed sides (fenders) on my 2014 Ram crew cab 6.4' bed. Thanks guys! I may be looking to do the frame kit package this spring!" Keith C. from Stilwell, KS
