Showing results for tags 'cavity wax'.
How To Attach The Cavity Wand to KBS Cavity Coater Aerosol In this video, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can. The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F. Cavity Coater Aerosol is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. Cavity Coater Aerosol provides a self-healing film which provides insane rust protection on hard-to-reach areas.
- cavity wand
- rust protection
(and 1 more)
Tagged with:
How To Attach The Cavity Wand to KBS Cavity Coater Aerosol In this video from KBS Coatings, we show you how to properly attach the easy-to-use Cavity Wand to the Cavity Coater Aerosol Can. The keys to your success are to shake the Cavity Coater Aerosol well before use, gently push straight down the spray tip while giving a slight twist, and applying when it is between 65-80F for ideal results. Cavity Coater Aerosol sprays the best when the Cavity Coater Aerosol is between 65-80F. Cavity Coater is the Perfect Solution for hard-to-reach areas that are prone to rusting! Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection on all metal surfaces. KBS Cavity Coater provides a self-healing film which provides insane rust protection on hard to reach areas.
- cavity wand
- rust prevention
(and 2 more)
Tagged with:
Cavity Wax Provides Rust Protection in Hard-to-Reach Areas Cavity wax is an excellent solution for providing rust protection in hard-to-reach areas. Rust develops when steel or iron is exposed to exposed to moisture and oxygen. To avoid rust it is necessary to seal the metal from these elements. While many areas of a car or truck can be easily reached to apply a rustproof paint or coating, other places are often difficult to reach, leaving the metal bare and exposed. Examples of these areas are inside frame rails, rocker panels, fenders, doors, tailgates, windshield cowls, and posts. Cavity wax can be used to provide a barrier against salt, dirt, and moisture in these areas as well as seal the welds and seams that rustproof paint or coating can’t reach. Cavity wax, also called rustproof wax, is a solvent-based water repellant wax that doesn’t completely harden but remains soft and pliable and therefore doesn’t crack, chip or peel. As well, it is self-healing if scratched. Because of its nature, cavity wax wicks into welds and seams. Cavity wax is often used when restoring vehicles and is important to use in body areas that have been repaired after an accident. Cavity wax is applied by spraying and is available in aerosol can versions as well as in paint cans for use in compressor driven wax spraying equipment like an auto body Schutz applicator type gun. The surface is coated with about a millimeter of cavity wax for proper coverage. In some cases where the wax cannot reach the area to be protected by the nozzle of the spray gun or aerosol can a piece of flexible hose, commonly called a spray wand, can be attached and to reach the cavities. The hose can be fed or snaked around corners and into areas that were previously out of reach. Spray wand inserted into cavity A cone-shaped nozzle disburses a stream of cavity wax perpendicular to the hose to help fully coat the cavity. Spraying while pulling the wand from the cavity at a rate of about two inches per second works best. Also, as the extension cavity wax wand is pulled from a cavity, individuals using the spray-gun should release the spray-gun trigger to avoid overspray. Close Up of spray wand tip Before the wax is applied the surface should be as free as possible of grease, wax, and readily accessible loose scaly rust. When applying inside cavities, make sure that all drain holes remain open. Cavity wax should not be applied to exhaust systems as it will produce smoke and can be flammable. It’s important to know that any grinding, cutting, or heating with a torch can cause the cavity wax to run. Any work which raises a part’s temperature above 160°F should be done before cavity wax is applied. KBS Coatings offers Cavity Coater as a solution for providing rust protection in hard-to-reach areas. Cavity Coater is a single step, super-penetrating corrosion inhibiting coating (CIC) designed for long term protection of all metal surfaces. It provides a self-healing cavity wax film tested to render more than four thousand hours of salt spray protection; over 4 times the protection of conventional cavity waxes. Cavity Coater resists road salt, alkaline solutions, and chemicals and for especially hard to-reach-areas the Cavity Wand is offered to extend the reach of aerosol Cavity Coater with a reusable 48” hose that features a 360-degree spray tip. The Cavity Wand requires only a 1/8” hole to insert and is easily cleaned. Cavity Coater is available in quart, gallon, and aerosol versions. Cavity wax is an excellent solution for providing rust protection in hard-to-reach areas and is perfect for brand new and older vehicles. KBS Coatings Cavity Coater product information is available HERE. Videos demonstrating use of Cavity Coater and the Cavity Wand can be seen HERE.
- cavity wax
- cavity coater
(and 2 more)
Tagged with:
Does the Cavity Coater kill the rust, and what do mean when you say self healing?
is this product effective on the insides of frames and panels that already have some rust? will it coat and seal up current rust in these areas? or is this just for new metal to prevent future rust?
"I purchased in November but was finally able to put the stuff on today. I bought the Cavity Coater with spray gun and 36" wand. This process went so much smoother than expected. Once I figured out the psi and the nozzle without the wand it was kind of fun. Customer service has been great! I called 3 different times and each time has been very pleasant, informative and helpful. I asked about regulator settings for the spray gun and set it up at 55psi. Worked great. Time will tell if the Cavity Wax stands the test. I am optimistic to say the least. I sprayed both rockers, 4 full sized doors, both front fenders, tailgate, rear bumper and basically the whole inner bed sides (fenders) on my 2014 Ram crew cab 6.4' bed. Thanks guys! I may be looking to do the frame kit package this spring!" Keith C. from Stilwell, KS
- cavity wax
- cavity coater
(and 1 more)
Tagged with:
