August 18, 20215 yr comment_5348 What would be the best approach to drying the surface after KBS Klean is washed out? The surface is known to lose its energy fast, at the same time it must be dry. So the longer the drying time, the less surface energy remains. Are there any methods beside heating it up? Link to comment https://success.kbs-coatings.com/topic/2946-surface-drying/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 19, 20215 yr comment_5349 You can use a clean dry towel to dry or apply heat to dry the surface after the surface has been cleaned with KBS Klean and rinsed. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2946-surface-drying/#findComment-5349 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 19, 20215 yr Author comment_5350 Would spraying the surface with water soluble and more volatile substance like Isopropanol after KBS Klean has been rinsed be an option? Link to comment https://success.kbs-coatings.com/topic/2946-surface-drying/#findComment-5350 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 19, 20215 yr comment_5351 Isopropanol leaves a residue behind, so we do not recommend rinsing with that as this defeats the purpose of using a water based cleaner and degreaser like KBS Klean. Link to comment https://success.kbs-coatings.com/topic/2946-surface-drying/#findComment-5351 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
