August 4, 20197 yr comment_4590 Hello all. I'm very new to this. I need to order a kit to the the underside of our 2001 F-250. It's the extended cab with an 8ft bed. What item would I need to order? I was told we need the entire kit. Thank you. Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 5, 20197 yr comment_4591 For the entire underside of an F-250, grab the Large Frame Coater Kit. This Kit has everything you need to clean, etch and coat the underside of the F-250. Your Success is Extremely Important To Us! We want your project to be a complete success so please be sure to read through carefully the following documents which will ensure your success using KBS Coatings. RustSeal Directions: https://www.kbs-coatings.com/rustseal-directions.html RustSeal: https://www.kbs-coatings.com/RustSeal.html RustSeal Kits: https://www.kbs-coatings.com/stop-rust-paints.html RustSeal Application Videos: https://www.kbs-coatings.com/instructional-videos.html#rs RustSeal Flow Chart: https://www.kbs-coatings.com/rustseal-flow-chart.html RustSeal How-To Section: https://www.kbs-coatings.com/how-to-use-kbs-coatings.html RustSeal Fix-It Guide: https://www.kbs-coatings.com/fix-it-guide-rustseal.html Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/#findComment-4591 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 6, 20197 yr Author comment_4592 So, 100ft for the F-250, got it. Do we need the Rust Blast or the #1 Thinner that comes in the other kits? The F-250 only 42,000 original miles, but it is a 2001. Do we need those other two items because of the age? Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/#findComment-4592 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 6, 20197 yr comment_4596 The Large Frame Coater Kit includes a gallon of RustBlast. The KBS #1 Thinner can be used to thin RustSeal if you are spraying RustSeal or can also be used for clean up. Some of the other kits include a top coat. Will the frame be exposed to sunlight? Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/#findComment-4596 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 8, 20197 yr Author comment_4602 Although not our truck, it is very much like this image, very stock; http://masbukti.com/ford/ford-f250/2001-ford-f250/1 Thank you very much for the replies so far. Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/#findComment-4602 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 8, 20197 yr comment_4603 Most people doing trucks like this do not worry about a top coat unless the truck is a show truck (being displayed). Grab the Large Frame Coater Kit. This Kit has everything you need to clean, etch and coat the underside of the F-250. Please let us know if we have answered your questions and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2531-2001-f-250/#findComment-4603 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
