June 1, 20188 yr comment_4236 Wondering how much heat Rust Seal will tolerate. Am re-doing re-packable motorcycle mufflers and thinking about coating the internal baffle with Rust Seal. Otherwise, I can use the Xtreme Hi-Temp coatings that I have. Just thought that Rust Seal due to its consistency, might be a little more tenacious if it would tolerate say, 400º Thank you! Link to comment https://success.kbs-coatings.com/topic/2278-heat-limits-of-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 1, 20188 yr comment_4237 RustSeal is good up to 600F, so 400F would be no problem at all. Please be sure to check out the complete RustSeal Directions and let us know if we can assist you in any other way. Link to comment https://success.kbs-coatings.com/topic/2278-heat-limits-of-rustseal/#findComment-4237 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
