Guest Posted July 24, 2017 Report Share Posted July 24, 2017 I have 15 gallon fuel tank I'm sealing with your Tank Sealer. Can I take the excess Tank Sealer that I drain out of the tank and put it back into the can and seal it up? Quote Link to comment https://success.kbs-coatings.com/topic/2219-reusing-tank-sealer/ Share on other sites More sharing options...
KBS Coatings Posted July 25, 2017 Report Share Posted July 25, 2017 No, please do not try to re-use drained out Tank Sealer. Drained Sealer cannot be saved & re-used as it has been exposed to atmospheric conditions and will cure & harden in the can. (WARNING: Do not put lid on can before curing is complete as pressure may build within can and pop lid. Dispose of any hardened Sealer properly in accordance with federal, state, and local regulations.) Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2219-reusing-tank-sealer/#findComment-4115 Share on other sites More sharing options...
