Motor Coater on oil pan
Yes, you can coat your oil pan with Motor Coater. Because of where the oil pan is located, the absolute best way to do this is to clean the oil pan extremely well with KBS Klean, etch the surface with RustBlast and then seal up the oil pan with 2 thin, covering coats of RustSeal followed by 1 coats of Motor Coater.
Please check out the RustSeal Directions and Motor Coater Directions and let us know if you have any additional questions.
