January 23, 20179 yr comment_3995 I been thinking about using KBS Rust Seal to make Anti-Skid on my car trailer with 12 mesh brown Aluminum Oxide Grit. What would you do different i.e. reduce, not reduce, spray not spray, brush not brush etc. 1. Three step system for rust protection. 2. Roll on one coat Galvanized Steel Rust seal. 3. Brush on second coat Rust seal and every six inches put down 12 mesh brown Aluminum Oxide Grit.4.One more rust seal coat. 5.Spray Fusion Self-Etch Primer. 6. Spray Top coat with KBS Black top OEM Stain black. Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 23, 20179 yr comment_3996 The process you describe sounds ideal. How are you prepping the surface before you paint on the RustSeal? Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/#findComment-3996 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 23, 20179 yr Author comment_3997 I was thinking blast or KBS paint remover along with wire wheel. Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/#findComment-3997 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 23, 20179 yr comment_3998 If you want to strip off a previous coating, use KBS Strip followed by KBS Klean and then followed by RustBlast. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/#findComment-3998 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 23, 20179 yr Author comment_3999 Do you think the 12 mesh brown Aluminum Oxide Grit will break off? Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/#findComment-3999 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 23, 20179 yr comment_4000 If you adhere the aluminum oxide grit well and coat over it with RustSeal and BlackTop, there is really no way it can break loose. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2162-car-trailer-anti-skid/#findComment-4000 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
