Motor Coater over Rust Seal
I was reading and noticed Rust Seal needs to be top coated if it's going to be in the sun. I like some of your Motor Coater colors. Can I use Motor Coater over the Rust Seal? If so, how would I prep the Rust Seal?
Yes, you can top coat RustSeal with Motor Coater.
There are three effective ways to topcoat RustSeal effectively so that the coatings bond & fuse together.
1) Apply Motor Coater once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity).
2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply Motor Coater.
3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply Motor Coater.
You can feel free to choose the method that will work for you.
