Guest Posted November 16, 2016 Report Share Posted November 16, 2016 Will Gold Standard Tank Sealer hold work for a dexron oil tank? The tank is to large to rotate. Can I brush this product on? Quote Link to comment https://success.kbs-coatings.com/topic/2143-tank-sealer-and-dexron-oil/ Share on other sites More sharing options...
KBS Coatings Posted November 23, 2016 Report Share Posted November 23, 2016 Yes, you can use the KBS 3-Step Tank Sealing System on a dexron oil tank. Yes, if you have access, you can brush on 2 thin, covering coats of Tank Sealer. Please check out the Tank Sealer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2143-tank-sealer-and-dexron-oil/#findComment-3956 Share on other sites More sharing options...
