Guest Posted October 25, 2016 Report Share Posted October 25, 2016 Can I use your KBS Strip inside my fiberglass fuel tank? Quote Link to comment https://success.kbs-coatings.com/topic/2135-kbs-strip-in-a-fiberglass-fuel-tank/ Share on other sites More sharing options...
KBS Coatings Posted October 26, 2016 Report Share Posted October 26, 2016 Yes, you can use KBS Strip to strip old tank sealers out a fiberglass tank. When stripping a Fiberglass Tank, surface contact with KBS Strip should be kept to a minimum to avoid the attack & weakening of the fiberglass resin.) Please check out the Tank Sealer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2135-kbs-strip-in-a-fiberglass-fuel-tank/#findComment-3916 Share on other sites More sharing options...
