Guest Posted October 17, 2016 Report Share Posted October 17, 2016 I have a tank that is leaking. I would like to coat it from the inside but it's not possible. Can I apply this to the outside of the tank? Is there anything else you have that could help with the leaks plus the tank sealer? Quote Link to comment https://success.kbs-coatings.com/topic/2133-tank-sealer-on-outside-of-tank/ Share on other sites More sharing options...
KBS Coatings Posted October 26, 2016 Report Share Posted October 26, 2016 Although it is always best to prep (KBS Klean and RustBlast) and seal (Tank Sealer) the inside of your tank, you can also prep and paint the Tank Sealer on the outside of the tank if that is your only option. Please check out the Tank Sealer Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2133-tank-sealer-on-outside-of-tank/#findComment-3914 Share on other sites More sharing options...
