Guest Posted September 22, 2016 Report Share Posted September 22, 2016 I have a hole in the floorboard of my car about 5'' x 5". Will the KBS Patch fix this? Quote Link to comment https://success.kbs-coatings.com/topic/2119-hole-in-floorboard/ Share on other sites More sharing options...
KBS Coatings Posted September 23, 2016 Report Share Posted September 23, 2016 Yes, you can patch a 5" by 5" hole in your floorboard. Clean the floorboard with KBS Klean, etch the floorboard with RustBlast, then seal up the floorboard with RustSeal. Once the RustSeal has cured 24 hours, scuff up the edges of the hole and apply the KBS Patch to the hole. Once the KBS Patch is cured, you can paint it with RustSeal to match the surrounding areas. Please check out the KBS Patch Directions and the RustSeal Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2119-hole-in-floorboard/#findComment-3883 Share on other sites More sharing options...
