September 21, 201610 yr comment_3881 Do I need to use any of your prep products KBS Klean and Rust Blast? Or can I just paint right over the rust? Link to comment https://success.kbs-coatings.com/topic/2118-prep-for-rust-converter/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 27, 201610 yr comment_3926 KBS Rust Converter is not designed to use on any non-rusty surfaces or surfaces where you have a mix of rusty areas and non-rusty areas. Use a wire brush or sandpaper to remove as much loose and flaky rust as possible. If needed, clean the surface with KBS Klean. Please check out the KBS Rust Converter Directions and let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/2118-prep-for-rust-converter/#findComment-3926 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
