Guest Posted June 14, 2016 Report Share Posted June 14, 2016 I have an aluminum water tank for my cows that is leaking. Will the KBS Patch seal this? Quote Link to comment https://success.kbs-coatings.com/topic/2052-kbs-patch-seal-water-tank/ Share on other sites More sharing options...
KBS Coatings Posted June 17, 2016 Report Share Posted June 17, 2016 Yes, KBS Patch will seal up an aluminum tank. Will you patch from the inside or outside? Quote Link to comment https://success.kbs-coatings.com/topic/2052-kbs-patch-seal-water-tank/#findComment-3760 Share on other sites More sharing options...
Guest Posted June 17, 2016 Author Report Share Posted June 17, 2016 I was planning on the outside. What do you think will work best? Quote Link to comment https://success.kbs-coatings.com/topic/2052-kbs-patch-seal-water-tank/#findComment-3761 Share on other sites More sharing options...
KBS Coatings Posted June 17, 2016 Report Share Posted June 17, 2016 Yes, sealing up the outside would be great. Ideally, we would like to see the inside of the tank sealed up with the KBS 3-Step Tank Sealing system, but Tank Sealer has not been certified for drinking water. The KBS Patch will seal it up just fine for water. Quote Link to comment https://success.kbs-coatings.com/topic/2052-kbs-patch-seal-water-tank/#findComment-3762 Share on other sites More sharing options...
