Guest Posted May 5, 2016 Report Share Posted May 5, 2016 What wavelength UV is required for curing of KBS Patch? Would a high power UV leak detection dye light work? Quote Link to comment https://success.kbs-coatings.com/topic/2024-what-uv-wavelength-required-for-curing/ Share on other sites More sharing options...
KBS Coatings Posted May 6, 2016 Report Share Posted May 6, 2016 The KBS UV Light operates at 390 to 395nm and that is what we recommend. The light you describe should work great to cure the KBS Patch. Please check out the KBS Patch Directions and let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/2024-what-uv-wavelength-required-for-curing/#findComment-3688 Share on other sites More sharing options...
