althezenman Posted March 16, 2016 Report Share Posted March 16, 2016 I understand the recommended way of using body filler (2 coats KBS -> Body Filler-> 300 Grit-> Rust Seal) but sparing all the details of why, there may be a time in my project where Rustblast will come in contact with cured Bondo before it is coated with RustSeal. I am curious as to the effect of Rustblast on the Bondo. Is there any problem with coating RustSeal over Bondo that has been exposed to RustBlast? Quote Link to comment https://success.kbs-coatings.com/topic/1986-rustblast-and-body-filler/ Share on other sites More sharing options...
KBS Coatings Posted March 18, 2016 Report Share Posted March 18, 2016 RustBlast should not affect the fully cured Bondo in any way. All you have to do is wipe the RustBlast off and then let it dry, then scuff the Bondo with 300 grit before applying the RustSeal over the Bondo. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1986-rustblast-and-body-filler/#findComment-3617 Share on other sites More sharing options...
Hal Kresser Posted August 29, 2021 Report Share Posted August 29, 2021 I'm about to finish the metal work on a metal table, I have a few places that will require a little filler (bondo). Should I apply KBS Klean, prior to filling? If I do, will I need to reapply before applying Rust Seal? Hal Quote Link to comment https://success.kbs-coatings.com/topic/1986-rustblast-and-body-filler/#findComment-5355 Share on other sites More sharing options...
KBS Coatings Posted August 30, 2021 Report Share Posted August 30, 2021 It is best practice to prep the surface with KBS Klean and RustBlast and then seal up the surface with Rusthttps://www.kbs-coatings.com/rustseal.htmlSeal before doing your filler/bondo work. This helps to prevent the filler/bondo from popping off. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1986-rustblast-and-body-filler/#findComment-5356 Share on other sites More sharing options...
