Yes, you can strip out the inside of your aluminum gas tank with KBS Strip.
As a general rule, 1 quart of KBS Strip will usually strip tanks from 1-12 gallons. 1 gallon of KBS Strip will usually strip tanks from 12-50 gallons.
Tank Stripping Directions
Pour some KBS Strip into tank and carefully rotate tank to allow contact with all sides. It may take multiple applications of KBS Strip to finish the job completely. Old Sealer may come loose in big chunks or small pieces so use a long tweezers-type tool to help remove it from the tank. After stripping is complete, rinse tank generously with water and proceed with the KBS 3-Step System for Fuel Tank Preparation & Sealing. (NOTE: When stripping a Fiberglass Tank, surface contact with the stripping agent should be kept to a minimum to avoid the attack & weakening of the fiberglass resin.)
