Hadley Posted January 18, 2016 Report Share Posted January 18, 2016 Can KBS MAXX Clear be applied directly to clean, sandblasted metal? I am looking for a clear sealer to apply to an old steel boiler that has been sand blasted. I do not want to change or add any color but want to protect it from rust. (the steel is inside) Quote Link to comment https://success.kbs-coatings.com/topic/1928-maxx-clear-over-sandblasted-metal/ Share on other sites More sharing options...
KBS Coatings Posted January 18, 2016 Report Share Posted January 18, 2016 Yes, KBS MAXX Clear can be applied over sandblasted metal as long as the sand was clean (not recycled) and you blow the surface off with clean air before applying the KBS MAXX Clear. It is very common for KBS MAXX Clear to be sprayed over metal because it comes in a flat finish as well as a satin or gloss finish. Please check out the KBS MAXX Directions and let us know if you have any additional questions. Thank you for choosing KBS Coatings. Quote Link to comment https://success.kbs-coatings.com/topic/1928-maxx-clear-over-sandblasted-metal/#findComment-3485 Share on other sites More sharing options...
