Showing results for tags 'clear coat'.
DiamondFinish Clear is the Preferred Clear Coat of Fishing Lure Makers! 👍Easy Application 👍Insane Durability 👍Water Clear Shine 👍High Solids = More Coverage Per Coat 👍Ideal For Immersion in Water
- diamondfinish clear
- crankbaits
(and 2 more)
Tagged with:
“1925 Essex. First, primed the frame with your Red Oxide RustSeal. Then he used your Buick Red Motor Coater for the color. Then clear coated the Motor Coater with DiamondFinish Clear.” -Melba C.
- frame paint
- clear coat
(and 3 more)
Tagged with:
“Used DiamondFinish Clear to coat my new aluminum flagpole. Product went on like a dream. Flagpole looks great and my DIY coating saved me a couple hundred dollars for a "factory finish”. The product appears to be very tough, withstanding the constant "clanking" of the halyard clips. Now I'm looking for other applications!” -Kevin from Portland, TN With a little imagination, DiamondFinish Clear has an unlimited number of applications for clear coating over steel surface as well as non-ferrous surfaces like polished aluminum. DiamondFinish Clear is a crazy t
- uv stable clear coat
- durable
- (and 3 more)
At KBS Coatings, we love Rat Rods just as much a Classic Car restored to original OEM perfection. Rat Rods are really fun and allow for creativity and artistry. But as with any vehicle, you need something to protect the vehicle and DiamondFinish Clear is an ideal clear coat to keep a patina look on your Rat Rod. Check out the 1974 Challenger and the beautiful stainless steel patina look.
- challenger
- clear coat
(and 3 more)
Tagged with:
DiamondFinish Clear is one of the most versatile clear coats on the market. DiamondFinish Clear is an ideal clear coat for restoring any painted wood surfaces including pinball machines because DiamondFinish Clear permanently bonds to the finish on the wood and adds gloss, durability and protection from the steel pinballs beating and banging on the surface. DiamondFinish Clear can also be used to seal and clear coat bare wood surfaces. The key to sealing a bare wood surface is thinning DiamondFinish Clear 30-50% with KBS #1 Thinner. This initial thinned out coat of DiamondFinish Cl
- clear coat painted surface
- restoration
(and 2 more)
Tagged with:
Because DiamondFinish Clear is a moisture cured urethane, which means it is cured and strengthened by moisture, it is absolutely ideal for all marine type applications. DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings for a hard durable and flexible finish. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- moisture cured urethane
(and 2 more)
Tagged with:
- crank baits
(and 2 more)
Tagged with:
DiamondFinish Clear was used to restore the front on my Fifth Wheel. DiamondFinish Clear is a crazy tough Clear Coat that can be applied to faded fiberglass to bring it back to life. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- restored fiberglass
(and 1 more)
Tagged with:
“Flame painted copper is done with a torch. NO paint. We use the DiamondFinish Clear to seal the copper and keep the colors permanent.” -Randy A from Scottsdale, AZ DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal (ferrous and non-ferrous) or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- torched copper
(and 1 more)
Tagged with:
I am so confident with my final product as I have a year of using KBS Maxx satin clear under my belt. My clients are ecstatic about the results and so am I. Thank you KBS for offering such an incredible product. -Dan M. KBS MAXX Clear --> https://www.kbs-coatings.com/KBS-Maxx-Clear.html
- clear coat
- satin clear coat
(and 1 more)
Tagged with:
“This is my original artwork over a red Lyon - Washburn Guitar. After a few coats of inferior products I needed that glass finish and decided to go with the KBS DIAMONDFINISH CLEAR and after only two coats from my HVLP gun the result was perfect and EXACTLY what I was looking for. Thanks so much for the product and letting me share this work of love with you. I will be using this product to finish all my rebuilds.” - Ron S. https://www.kbs-coatings.com/DiamondFinish-Clear.html
- clear coat
(and 1 more)
Tagged with:
DiamondFinish Clear: https://www.kbs-coatings.com/DiamondFinish-Clear.html
- fishing lure
- clear coat
(and 1 more)
Tagged with:
“Here are just a few pictures of what I do, new metal art. I am looking forward to much better sales this year due to using the KBS Diamond finish. WOW!!!, what a difference. Everything has a completely different dimension than before. The different colors and even the plain raw metal stands out. I say we have the "WOW" factor now. Some of our customers who have already seen the difference are amazed. We are really excited that we discovered KBS Coatings!” -iMetalist from Burleson,TX https://www.kbs-coatings.com/Clear-Coats.html
- clear coat
(and 1 more)
Tagged with:
“This was a 4 X 8 foot plywood sign (double-sided) that I originally did about 8 years ago, for a friend's restaurant. It was very faded and weathered; but the basic plywood was still in good shape. So we sanded it well, primed and re-lettered it.(hand painted). Then put the KBS Diamond Clear on it. Looks great!! It sits out in a parking lot, with one side in the sun for most of the day ... I'm very satisfied with the product, so far.” -Dale F. DiamondFinish Clear
- plywood sign
(and 1 more)
Tagged with:
“When undertaking a custom engine install on my 1972 Buick Riviera the KBS BlackTop OEM Satin Black did absolute wonders for refreshing the engine bay. My choice of color for the new crate engine is KBS MG Maroon Engine Paint. KBS clear was used for the final clear coat on the car and when spraying the KBS clear in several light coats I had excellent results. I will use KBS paint products again for future restoration projects” -David P. BlackTop | Motor Coater | DiamondFinish Clear
- 1972 buick riviera
- engine restoration
(and 1 more)
Tagged with:
Will Diamond Clear stand up to continuous exposure to damp salt salt air? I want to coat stainless steel? Im looking for a clear coat for beach house.
- 1 reply
- clear coat
- beach house
(and 1 more)
Tagged with:
“DiamondFinish Clear came out really great after letting the base coat (Pettit EasyPoxy polyurethane/silicone) cure for a week and after only one coat of DiamonFinish brush-on clear, some wet sanding with 1000 and 2000 grit and compound in some areas and to fix a few sags due to shape of the object. ...I'm very happy with the result.” -Marinus Please check out DiamondFinish Clear.
- clear coat
(and 1 more)
Tagged with:
“A few years back I was searching for a product that I could brush on and level itself to a sprayed finish appearance. DiamondFinish Clear was it! I use this product to seal and finish out door public art sculptures. These photos are of the most recent project I'm working on which made the news during a press conference. Thank you for the quality professional Finish from KBS !! I'm also letting more people know how great this product is. I have been spraying and brushing finishes for twenty plus years and have never used a better product with a brush than KBS DiamondFinish Clear. Thank you!” -
“This clear-coat adds luster and value to our fishing lures. Our customers really appreciate the quality.” -RSR Lures DiamondFinish Clear
- fishing lures
- clear coat
(and 1 more)
Tagged with:
Can diamondfinish coat be used on exterior wood surfaces that have been stained with oil based stains such as Minwax.
Is KBS DiamondFinish Clear resistant to the degrading effects of UV? Can KBS DiamondFinish Clear be applied to exterior brick in order to create a barrier to prevent water penetration? If KBS DiamondFinish Clear is considered suitable for application to brick, how long can the product be expected to last before it peels?
Hi, does DiamondFinish Clear dry glossy like a 2k paint, or would I need to cut and buff it like an acrylic clear? Also, will it fade over time like regular 1k acrylics?
- 1 reply
- cut and buff
- clear coat
(and 1 more)
Tagged with:
Can KBS MAXX Clear be applied directly to clean, sandblasted metal? I am looking for a clear sealer to apply to an old steel boiler that has been sand blasted. I do not want to change or add any color but want to protect it from rust. (the steel is inside)
