In general, it is always best to get as much of the old sealer out as possible so the KBS Tank Sealer is adhered to the actual surface and not another coating.
What color is the old sealer in your tank? If we know that, we can give you some suggestions for how to get it out.
KBS Strip should take out the old liner. It is a good idea to keep the KBS Strip in contact with the tank liner for a few hours and then drain while capturing the KBS Strip so you can use it again. If you do that a few times on each side, you should be able to get all of the old liner out and then proceed to the KBS 3-Step Tank Sealing System.
Please let us know if that helps and if you have additional questions.
