August 27, 201313 yr Author comment_2858 ok I'll get some Fusion Self-Etch Primer. Shall I use a large can of tank sealer this time? Although the can I had should have been big enough, maybe the surface area was to large? Link to comment https://success.kbs-coatings.com/topic/1620-making-tank-watertight/page/2/#findComment-2858 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 27, 201313 yr Author comment_2859 The area in indented, so will fill with plastic padding or chemical metal before reshaping. Hope the other tins don't cost too much. So far it has worked out an expensive solution. Link to comment https://success.kbs-coatings.com/topic/1620-making-tank-watertight/page/2/#findComment-2859 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 27, 201313 yr comment_2860 Yes, get some Fusion Self-Etch Primer and a larger can of the Tank Sealer to make sure you have enough. Link to comment https://success.kbs-coatings.com/topic/1620-making-tank-watertight/page/2/#findComment-2860 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 27, 201313 yr Author comment_2861 what size can of Fusion Self-Etch Primer do i need, and how is it used? Link to comment https://success.kbs-coatings.com/topic/1620-making-tank-watertight/page/2/#findComment-2861 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 27, 201313 yr comment_2862 1 Pint should be fine. We have had customer pour it in, roll the Fusion around on the inside of the tank so the entire inside of the tank is coated. Allow to cure over night. Then apply another coat of the Tank Sealer. Link to comment https://success.kbs-coatings.com/topic/1620-making-tank-watertight/page/2/#findComment-2862 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
