August 25, 201016 yr comment_2060 Which is the ideal surface for Rustseal? 1.light rust 2.grit/sand blasted 3.wire wheel 4.sandpaper 5.? When using sandpaper, which is the ideal grit to give Rustseal the best "anchor" possible? When sand/ grit blasting, is it best to use very fine, fine or medium blast media? for best adhesion of rustseal. Thank you Link to comment https://success.kbs-coatings.com/topic/1429-ideal-surface-for-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 15, 201016 yr comment_2381 Sandblasted is ideal. Medium grit is great. With sandpaper, you can use 80-300 grit. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1429-ideal-surface-for-rustseal/#findComment-2381 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
