Showing results for tags 'frame paint'.
    • KBS MAXX Clear
    • KBS Top Coater 1K Aerosol
Found 16 results
  1. “1925 Essex. First, primed the frame with your Red Oxide RustSeal. Then he used your Buick Red Motor Coater for the color. Then clear coated the Motor Coater with DiamondFinish Clear.” -Melba C.
  2. "I couldn't be happier with your product. I used BlackTop on my 1955 Chevelle frame and it looks amazing. The finish and durability are amazing." -David L. BlackTop is a permanent, moisture-cured, 1K single component UV stable coating primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure.
  3. The Frame Coater Kit is a quart size 3-Step System Kit that includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coats of paint coverage. You get Top Quality Protection at a tremendous value! Detailed instructions included. KBS Coatings’ 3 Step System of RustSeal (a rust preventive coatings), KBS Klean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today. RustSeal is a paint or coating that chemically bonds to bare metal to form a permanent, moisture resistant finish that is flexible yet won't crack, chip, or peel. Because RustSeal is moisture-cured, this superior coating is made even stronger by continued exposure to moisture. RustSeal is also highly resistant to some of the most aggressive chemicals such as acids, alkalis, salts, abrasive materials, fertilizers, coal dusts, solvents, oils, and other refined petroleum products.
  4. This entire engine compartment was coated with KBS Coatings. RustSeal and BlackTop on the firewall and frame components. Motor Coater was used on the engine. Professional Results at a DIY Price.
  5. “I wanted to thank you for such a great product. I’m restoring my 1986 GMC Sierra Classic & wanted to freshen up the old rusty frame. I purchased the Large Frame Kit & was extremely impressed by how easily it was to use and how well it worked on even the rustiest of surfaces. The finished product was awesome! Thanks again!” -VS Large Frame Coater Kit
  6. BlackTop is a permanent, moisture-cured, UV stable coating primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure.
  7. “This frame from my 1956 Chevy was extremely rusted and I wasn't sure how it would turn out however, as you see it's remarkable! I will use KBS products on all my restoration projects.” -Jeff M https://www.kbs-coatings.com/frame-coater-kit.html
  8. how much would I need to be able to cover the undercarriage of a 67 mustang?
  9. I have a 1970 Chevy C 10 that I wanted to repaint the chassis. The pervious owner sandblaster the frame and painted it but I don't like the way it looks. Am I able to use your all-in-one chassis kit over the paint that he use or does it have to be bare metal?
  10. Does KBS MAXX work for chassis? Or what is this for? Thank you!!
  11. I am building wench frame to put on truck. will I have to prime frame before I paint coating on frame? it will be welded together and brushed cleaned and all rust will be brushed cleaned and chemically removed. will I need a kit or just use the paint?
