Showing results for tags 'kbs maxx'.
Because RustSeal and KBS MAXX are incredibly durable coatings, there are thousands of applications for these incredible coatings. One of our customers used RustSeal and KBS MAXX to protect the lift in his garage. After prepping the surface, he applied both RustSeal and KBS MAXX with a brush and ended up with an incredible looking lift that will withstand the abuse that garage lifts have to endure!
- brush on 2k paint
- durable coatings
- (and 4 more)
“1976 Honda trail 70 I restored using all KBS products. KBS Strip, RustBlast, Black & Crazy Plum MAXX paint & DiamondFinish Clear ... All products worked just like they said they would. MAXX & Clear sprayed perfect with high gloss an no runs ... As a matter of fact I couldn't make it run!!! All dried supper hard! Then used KBS UnderCoat inside frame. On motor cases I used the silver Motor Coater & topped it with the DiamondFinish Clear. I tell all my friends about how good KBS Products are!” -Robert T.
- motor coater
- diamondfinish clear
(and 2 more)
Tagged with:
Can KBS MAXX withstand the temperatures under the hood. I would like to do some parts in the engine bay if it'll hold up.
Does KBS MAXX work for chassis? Or what is this for? Thank you!!
If I want to mix your standard Maxx colors to get different color options, do you have color mixing samples along with their mix ratios for Maxx paint ?
